Please help. I have several older VHS tapes where the top of the picture is distorted. Is there anything out there that will stabilize the picture so it does not look like the top of someone's head is floating away?
Thank you,
msns_pet
That sure is a bugger!!!!!!!
Is it like the top 25% of the screen floats away at 45 degrees to the footage at the bottom?
Someone may correct me but a TBC might be your best bet.
I used to have this with some tapes, but trying them on a different VCR, in most cases, seemed to fix it.
Never understood why.
Look up TBC in the glossary, it does not mean 'to be confirmed', as I once thought
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
try them on an old 2 head VCR.
JVC VCRs have a "Video Stabilizer" (in addition to a Video Calibration setting). If you're going to be doing a lot of tape to DVD conversions, you should definitely invest in one -- with TBC.Originally Posted by msns_pet
If you're just doing a few videos, you might look into just renting a JVC for a little while.
However, one thing I have run into myself is that sometimes a tape will be so bad that even with video stabilization and TBC, a file is created that plays fine on your computer (as an MPEG file) but which TMPGEnc DVD Author can't "handle" -- produces a DVD with lost audio synch (the weird part being that other programs, such as DVD MovieFactory CAN create a good DVD from the same file).
VCR won't take tapes
By llmercll in forum Newbie / General discussionsReplies: 10Last Post: 19th Oct 2013, 19:03 -
Is there a VCR that will play VHS-C tapes without an adapter?
By moxiecat in forum RestorationReplies: 23Last Post: 25th Oct 2012, 03:24 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Best VCR to clean up old VHS camcorder tapes?
By dubarry in forum Capturing and VCRReplies: 1Last Post: 26th Jan 2011, 02:09 -
How to adjust VCR tracking for EP tapes
By timmus in forum RestorationReplies: 12Last Post: 15th Jan 2011, 02:12
