I'm using DVD Author feature of IfoEdit to create DVD format files (.IFO, .VOB etc) with .m2v, .wav and .sub files.
The result is fine. However I cannot create menus with it.
Does anybody know other tool that accepts audio, video and subtitle files and generate DVD format files?
MenuEdit
New comments, Jan 12
MenuEdit is a DVD vob file editor for Windows which eliminates a root of the problem - removes buttons from dvd menu screens and replaces unwanted material with what you like. No button - no problem.
Otherwise NO
I think however, You should just elect to use a regular DVD AUTHORING program rather than a 'TOOL'
as the answer to your question generically speaking is : ANY AUTHORING APPLICATION CAN DO THAT -
you are right. I should put in the Authoring section instead of the conversion.
I will check the way you suggest again.
I need IFOedit for Mac
By bryceguy in forum MacReplies: 7Last Post: 14th Dec 2011, 11:45 -
Ifoedit, vobs have to be not less than a 1gb?
By Remyisme in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 05:12 -
ifoedit question
By J. Baker in forum Newbie / General discussionsReplies: 3Last Post: 17th Sep 2007, 03:10 -
IFOedit question...
By Djard in forum Newbie / General discussionsReplies: 6Last Post: 4th Aug 2007, 00:42 -
adding CC with ifoedit
By loster in forum Authoring (DVD)Replies: 0Last Post: 9th May 2007, 19:15
