what's an .ogm file. i played the file on vlc an animation of course... can i convert this file into a vcd or svcd and how? what program should i use for this task?
thanks
dj_yerba says: legalize it!
VIVA CHILE MIERDA! -
The video part of our OGM files has been encoded with XviD, and the audio part has been encoded with Ogg Vorbis.
If you can play it with MplayerOSX you should be able to convert it with the many apps that use mencoder
ffmpegx for example
Probably because the ogg vorbis audio could not be decoded. Try this: Select the vcd quick preset. Under the audio tab in ffmpegx select passthrough, uncheck encode audio and make sure keep elementary streams is checked in the options tab.and also tried to decode it using ffmpeg to vcd but the conversion failed... any ideas why?
Download the Ogg Vorbis Quicktime component here: http://www.versiontracker.com/dyn/moreinfo/macosx/13012 and open the file created by ffmpeg in quicktime. Export it to .wav or .aiff and then go back to ffmpeg. Open up the new quickitime file and convert it to mp2 audio.
Mux it with the mpeg1 video in the tools section and then author the files as a vcd. Burn.
HTH
I now wait for the gurus to post an easier way of doing this... -
well... first of all, i'd like to thank all of you for your support!
i've downloaded the mplayer osx2 latest version (b6 i believe), and the file now plays without any drama... first problem solved!
i dont have many app for conversions so i used ffmpeg for my purposes. as told before i couldn't make it to vcd, but then i thought why not trying to svcd, and it worked... the ffmpeg progress started to do the conversion, i don't know why but at some point failed, cause it said that couldn't find the mpa file (i believe .mpa is some kind of audio file)... conclusions...practically i just were i started, i cannot make any conversions.
ok zero six, i'm confirming that i can play the file, i'llbe very grateful if you can give a hand with this matter.
and pixeljammedia... i'll give it a try to your suggestions and i'll post back with the results. (i', already downloading what you told me and i'll install it as soon as i get home)
thanks all of youdj_yerba says: legalize it!
VIVA CHILE MIERDA!
what is best and multi video fomat
By jaggalink in forum Video ConversionReplies: 1Last Post: 2nd May 2008, 09:03 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 20:08 -
.ogm to DVD
By Faty100 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:14 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 14:27 -
movie with Xivd fomat!!!
By dewolf in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:55
