Hello, firstly i'm not sure if this is the correct forum but its the one that seemed to suit my question the most...
I have made an animation in 3DS Max and i would like to put this onto a PAL DVD. Its only a small animation (5 minutes) so I can use the maximum bitrate for a DVD (9,800k/s (i think)). Basically, all I want to do is render this animation so it looks optimal.
My questions are these:
1. Should I render in image format (tga) and then join them later or should I render to uncompressed avi.
2. When encoding to DVD Mpeg2 should I use CBR at 9,800 or should I use VBR and what settings should I use in tmpgenc. (I have been through 90% of the guides on here and various other sites and have tried many ways to get my animation looking crystal but i just cant seem to get it right)
3. Should i render my animation to 720*576 or should i do it larger and then resize it when encoding?
thanks for any help
Hi
I don't know "tga", so would lean towards the uncompressed avi - purely because it's uncompressed and will therefore retain all / most of the original quality.1. Should I render in image format (tga) and then join them later or should I render to uncompressed avi.
This guide:2. When encoding to DVD Mpeg2 should I use CBR at 9,800 or should I use VBR and what settings should I use in tmpgenc.
http://dvd-hq.info/Compression.html
Is REALLY good for the settings in TMPGEnc and makes specific reference to settings for animation footage.
Not sure about the CBR vs VBR. I've not done animation, but would guess CBR as VBR is more for footage that has a mixture of still / slow moving (not requiring such a high bitrate during encoding) and faster action (requiring higher bitrates during encoding). I may be totally wrong - just an educatde guess. (Constructive) Comments anyone?
I can't see the need to go bigger only to go smaller during the encoding - I guess it will just take longer. Again, only an educated guess so don't flame me if I'm wrong.3. Should i render my animation to 720*576 or should i do it larger and then resize it when encoding?
Hope that helps. Good luck...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Need advice on recording, rendering and encoding.
By Luponius in forum Newbie / General discussionsReplies: 22Last Post: 14th Mar 2011, 03:21 -
Does a better video card improve the quality of video when rendering?
By raysolomon in forum EditingReplies: 8Last Post: 3rd Mar 2009, 21:24 -
Video Rendering
By tapal in forum Authoring (DVD)Replies: 4Last Post: 23rd May 2008, 10:30 -
Terminilogy: Rendering vs Encoding
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jul 2007, 00:44 -
Need some basic knowledge of rendering/encoding.
By devizboy in forum Newbie / General discussionsReplies: 13Last Post: 11th Jul 2007, 12:30
