I just converted 'finding nemo' on dvd to vcd. The first time i ripped it to my harddrive with dvd decrypter but realized some of the extras were embedded with the movie, so i had to something.
I used dvd shrink and clicked on reauthour and selected my dvd rom with the movie inside and i in the 'movie' category there were 2 files, and there was one with the embedded extras and the other one was like the one i ripped with dvd decrypter.
Somehow it seemed that dvd shrink ripped faster then dvd decrypter or is this my imagination or what? I know the file was bigger in dvd decrypter but still....... can someone help?
What do you need help with.. doesn't seem like you had a problem. Just a question as to why dvdshink processed it faster than DVDdecrypter.
plus you answered your own question when you said "I know the file was bigger in dvd decrypter but still....... "
since you did a reauthor in dvdshirnk and did not process the whole dvd. Shrink only ripped the files that it needed and not all of the files like Decrpter did. Ripping less MB equals faster ripping times.
The new version of dvdshrink 3.1.4 has a new ripping engine also that is just as fast as dvddecrypter on some PC's (depending on CPU, memory etc.). -
Hi All
Can any body help??
I have installed various versions of DVDshrink they all fall over when I try to read the disk - works for about 20secs and the freezes my computer.
If I use dvddecrypter and the access the files all works ok
2.4 ATHLON 512 MEM WINDOWS XP HOME 160G DISK
Any Ideas? -
It prolly was offended when it saw that u TYPE IN ALL CAPS WHICH MEANS YOU ARE YELLING at us.
Run the program on the files on the computer, and don't f'n thread jack. By the way your keyboard is broken, caps lock must be broken.
Blah, blah, blah
DVD Decrypter 3.5.4
By jyeh74 in forum Newbie / General discussionsReplies: 6Last Post: 9th Mar 2010, 15:48 -
dvd decrypter
By dr strange in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 15:11 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Can't PlayBack DVD after using DVDShrink
By NatJm429 in forum Newbie / General discussionsReplies: 5Last Post: 19th Jun 2008, 23:22 -
DVDshrink problem with a new DVD
By mvp in forum Newbie / General discussionsReplies: 3Last Post: 26th Feb 2008, 14:01
