For some reason with DVD Shrink, when I put in a backup of a dvd and I hit open disk it says:
Failed to open file
The reason is: The system cannot find the file specified.
So when I try to use smart ripper, I choose file mode, choose all the files, and then hit start. It appears to work ok, except when I check the folder I rip to it only has 300 gigs on it. All the .vob files are smaller than what's on the backup dvd. When I look at the dvd in explorer it's a full 4.0 gigs.
This doesn't happen with all backups...only some.
Anyone encountered this before?
Try using windows explorer to copy the files to the hard drive. I have done this a few times on trouble DVDR's and it worked for me.
If your backups are giving you grief, just copy the original again.
That is what you make "backups" for, right ? It's a no-brainer, surely. -
Or DVDDecrypter ....ISO Read/Write mode.
Although I do have one DVD-R that will only copy "on the fly" with my B's Recorder Gold 5 that came with my LG 4040B....it craps out in DVDDecrypter also.....weird.
It might be that if you are using your DVD Rom drive to RIP....it may be ripping too fast.....just a thought.
When I try to Backup DVD on Shrink...
By lblaker in forum DVD RippingReplies: 10Last Post: 24th Mar 2010, 20:08 -
DVD Backup
By sixleaf in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2009, 00:50 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 15:55 -
Saw 4 does not backup using DVD Shrink
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2008, 03:11 -
DVDFab 4.0.2.0 Beta backup crashed Shrink - fixed(sort off)
By pchan in forum DVD RippingReplies: 1Last Post: 21st Dec 2007, 09:04
