There are so many ways to rip and encode DVD's its hard to choose which programs to use and what methods to do it. Ripping isn't a problem just use any ripping program to get your .ifo files. However encoding is where all the magic happens. I use Smartripper to rip. Now I want to know what is the best prog. to use for encoding. I currently use either DVDx1.6 or DVD2AVI w/TMPG. Which would be better??? Or is there other programs that are better than these?? i.e. flask
So what do you think is the best way to encode??
Thanx,
Fat J
Hi there,
There is no definate answer to this it is all about prefference i guess. TMPGenc is very good but takes very long time to encode.
CCE is very quick and quality is on par with TMPGenc.. so i guess i would use CCE as the main encoder if i were you... there are packages out there like the one you use that use the CCE encoder...
good luck.
Regards,hTK / M.O.A.H.K
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
burn in a subtitle in Xvid without re-encode
By Cazz in forum SubtitleReplies: 6Last Post: 2nd Sep 2011, 23:28 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
ConvertXtoDVD to encode and burn video files to DVD
By crowheart in forum Video ConversionReplies: 15Last Post: 16th May 2007, 22:50
