I'm trying to get files from a Philips set-top recorder (vob files + ac3 sound) edited onto dvd-r disks. Problem is averything I've tried wants to re-encode the files. All I want to do is chop out ad's etc but if possible have a transition between the two - is it possible with fairly simple software? Mydvd 5 does a reasonable job of cross fading the audio with a simple wipe etc, but I can't stop the thing 'hanging' 3/4 of the way through a job so I don't know what the output would look like.
I admit I don't understand the workings of these various formats, but most progs' seem to convert the vob from the recorder to another format to edit then back to vobs when it re-encodes. Surely these coversions affect the quality....no different to re compressing an mpeg file?
Thanks for any info, I've tried many demos - ulead, sonic, cyberlink but all seem to have something missing (or is that me)
Dave
try out womble mpeg video wizard. it's available from www.womble.com
edit's mpg's without re-encode.. easy interface too. (once you figure it out) Don't know about the fade's or wipes or anything though.. I never use them. -
Thanks for that, just downloaded the demo. I'll give it a try later when I get home.
try either movie factory 2 OR TMPGENC DVD Author. Either of these two programs will allow you to cut out various parts, etc. w/o reencoding.
You could also us dvdshrink, however, I think that the above apps would serve your needs better.
Mute and edit clip without re-encoding
By exon in forum Newbie / General discussionsReplies: 2Last Post: 31st May 2010, 09:30 -
Edit AVC video without re-encoding?
By RagingSloth in forum EditingReplies: 2Last Post: 30th Mar 2010, 09:53 -
Virtualdub - Edit without re-encoding (except at edit point)
By itsonlyme in forum EditingReplies: 2Last Post: 26th Feb 2010, 05:59 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Edit MPEG2 video without encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 13:05
