i have ATI rage with vid in
i can capture vid with ATI multimedia softwere that came with it to make a AVI file
but i cant capture the sound
i can hear the sound via line in adn then played though my sound card
i can capture the sound with windows sound recorder
to make a WAV file
but how do i combine them both
or can you tell me how to capture both in one file
do i need difrent software or what
just point me in the right direction PLEASE PLEASE PLEASE
<font size=-1>[ This Message was edited by: acemarkace on 2001-10-19 09:47:19 ]</font>
I haven't done any video/audio capturing, so not sure about saving the avi with audio. But as for joining the two I know you can use VirtualDub to join the two. If you are lucky, you won't have any synch propblems.
Open up virtualdub, open up your vid file and then select your filters/compression/etc. then go to audio -> wav file. Select the wav and then you can do direct stream processing or full processing mode (which will let you compress the wav to mp3, or some other format).
Encode a couple minutes see if the audio syncs. If not then first try this in virtualdub. Goto video -> frame rate. At the top of the dialog you will 3 radio buttons. Select the bottom one (it says something along the lines of change frame rate to match audio). Re-encode again. If it works great if not you'll have manually sync.
Good luck
-c
CamStudio AVI Files (WAV)
By foochuck in forum AudioReplies: 6Last Post: 7th Oct 2010, 20:50 -
DVD to AVI or WAV
By GarrettKooper in forum DVD RippingReplies: 2Last Post: 5th Aug 2010, 18:25 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 14:11 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 19:21 -
AVI to WAV in Virtualdub
By crumbworks in forum Video ConversionReplies: 20Last Post: 9th May 2008, 05:10
