Will this cause any player compatability issues? If I pick "Region Free" in DVD Shrink, does it mean it has no regional coding or all regional coding? I've heard some players can't play discs that don't have a region code specified...
Results 1 to 9 of 9
"A DVD that you make on a PC with a DVD burner or in a home DVD video recorder will play in all regions"
-taken from the dvddemystified.com FAQ -
There are no problems with this at all.
Region Free is the same as "ALL Region" in which means that any disc that is "ALL Region" will contain the region coding for all 6 DVD Regions and hence allow you to play DVDs from other countries on your own local player.
So I see no disadvantages with Region Free DVDs."Night Stalkers Don't Quit" - Regiment motto of the 160th Special Operations Aviation Regiment (Airborne) -
Right, but, I've heard that some standalone players won't play DVDs that don't have regional coding...it's a copyright protection kinda thingie.Originally Posted by freestyler
Ah, that's what I was wondering -- whether it meant "all regions" or "no regions". Thanks!Originally Posted by big_kel
The only "protection" mechanism I might worry about is RCE protection. If you don't remove that your discs may not play correctly. It's yet another option in DVD Shrink thats enabled by default. I've seen it on quite a few DVDs such as "Dogtown and Z Boys" and "Pumping Iron"
Not entirely true, because you can add region protection even on home authored discs.Originally Posted by freestyler
There are discs that can check to see if the region protection has been removed and refuse to play (this can be done with COMMAND SEQUENCES). Annoying if you don't catch it before you burn.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Playing AVCHD "BD5" discs incl menus from MultiAVCHD on PC
By R.A.J. in forum Software PlayingReplies: 1Last Post: 5th Apr 2011, 11:44 -
Samsung BD-UP5000 Region "A", Region "1"
By lastbutthree in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Sep 2009, 14:24 -
ONKYO DV-SP502E - region free - how long to hold "enter" ?
By Birgit1964 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Oct 2008, 14:26 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00
