I used to just print my cd jewl cas inserts on paper and it worked just as good as the labels u buy in stores... But now with DVd there is a bend in the case and im just wondering if i should buy the labels or again just print them on paper? Or will ordinary paper tear in the bends? thanks
Print your covers at 3240 X 2175 pixels. And you should be fine.
I use the perferated glossy ones. But I have used regular(well sort-of, it was card stock)and it worked fine. -
Any kind of paper will do as long as its thick enough. Even thin stock paper probably wouldn't tear or even have a noticable crease line where it folds, but the thinner the paper the crappier the printout is going to look, and if the paper is thin enough it gets bumps all over it wherever the ink is heavy. Glossy paper really does look alot better than matted if you can afford it, but you have to get the inserts.
I actually do buy the insert paper just because I'm lazy and don't feel like cutting the cover out. The inserts have perforated edges that just peel off, but the quality is no better than with regular glossy paper. -
I also use the perforated ones. They're really easy to use and look fine. In fact, some people have mistaken them for the real thing when I've scanned the original cover.
One challenge has been fitting them to the slim dual-disk cases I got a week or so ago. They're slightly too big, so I've been using a ruler and razor to trim about 1/8th inch off each side and they fit fine. I also have to reduce the font size on the spine...
Is Corels DVD Workshop II worth buying in this day and age?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 15th Apr 2010, 09:46 -
CloneDVD2 - worth buying with AnyDVD or not?
By trimicada in forum DVD RippingReplies: 14Last Post: 23rd Dec 2009, 11:52 -
Avanquest ConvertMovie worth buying?
By guitareth in forum Video ConversionReplies: 2Last Post: 12th Jul 2008, 10:42 -
Best way to save/print DVD case inserts?
By stantheman1976 in forum Newbie / General discussionsReplies: 1Last Post: 11th Dec 2007, 13:33 -
CD Jewel Case Inserts...best pricing?
By ChaunceyK in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2007, 14:10
