hi again
When I'm playing MPGs in media player 9, some of them will only show as being a short clip (usually under a minute) when they may be much longer.
The whole thing plays but there is no way to know how long they are or to seek ahead if I'm just checking the file out to see if it's something worth keeping.
Is this something with Media player 9 or the MPG file and is there a way to fix it?
Thanks.
Results 1 to 10 of 10
Increase knowledge, increase sorrow.
It does the same whenever you playback Lame encoded audio (MP3) with a Fraunhofer DShow filter (Windows OEM).
Maybe the audio track was encoded with the Lame ACM. -
maybe, but the same file can be opened in another computer with no problem
so my media player (or my configuration) is the problem
my friend and i have the same media player, soundcard, etc
so i dont hace a clue of what can it be...Increase knowledge, increase sorrow. -
Perhaps something you have installed has replaced or overridden the default MS MPEG decoder (if it's an MPEG 1 file) or your MPEG2 decoder is buggy.
Programs like Ulead's editing software and a bunch of others somethimes do this.
If it's an MPEG2 file, the easiest thing to do is try playing it with Media Player Classic, since it has it's own MPEG2 decoder and see if it does the same thing.
If you just have to keep using WMP, try getting yourself a copy of something like the Ligos decoder, which is DirectShow compatible. -
yeap that sould be the problem
cause i format and reinstall a friend's computer and everytime was ok until i install adobe premiere and after effect..
and that when it happen...
so now i know what is the origin of my porb
but i need those programs..
i'll give it a try with media player classic but i would like to fix that problem 'cause i like wmp9
tks
-StKIncrease knowledge, increase sorrow. -
in my previous post i mean, "everyTHING was ok..."
Cool. this previous post of mine might help you out. I still get emails about this one.
https://www.videohelp.com/forum/viewtopic.php?t=152598&highlight= -
noup
nothing seem to work
anyone has a clue?Increase knowledge, increase sorrow.
How to fix incorrect time? MKV rip displays as 14+ hrs long in all players
By elcoyoteloco in forum Video ConversionReplies: 2Last Post: 6th Feb 2011, 13:11 -
Playback of MPEG-2 movie burnt on a DVD stops after some time.
By ssukuru in forum Newbie / General discussionsReplies: 4Last Post: 16th Apr 2010, 04:31 -
Real-time Video Effects Media Player
By deathclaw in forum ComputerReplies: 6Last Post: 11th Feb 2010, 06:26 -
Video file time length is incorrect after converting to M2TS
By Alterego in forum Video ConversionReplies: 0Last Post: 18th Oct 2008, 11:54 -
"The movie contains an incorrect time value"
By oediv in forum MacReplies: 0Last Post: 2nd Aug 2007, 22:34
