hello,
i was wondering what can cause a dvd burner rated at 4x with 4x media, to burn at 2x?
i've recently purchased 4x media for my dvd burner and it was working fine at that speed. i use various programs from roxio to dvd decrypter and they are all sex to burn at 4x. now when it comes to actual burn speed, it writes at 2x. any suggestions as to why this may be happening?
Brand name media or cheap media?
"Art is making something out of nothing and selling it." - Frank Zappa -
Also burner not recognizing the media burning code will cause it to burn at 2x instead of 4x.Firmware updates sometimes include more media codes.
Crap media. Avoid firmware hacks or upgrades if at all possible. At least 1/3 of all problems reported on this forum result from crap media and/or firmware hacks/upgrades. (Another 50% of the reported problems result from use of VDub. The remaining problems boil down to lack of proper DirectShow audio or video filters.)
I would say media is the biggest factor but proper firmware upgrades are the way to go with the occasional screwed up firmware.If i didnt upgrade my 411s firmware then i wouldnt have been able to play dvd-r on my apex.I use virtualdub and dont have any problems using it,its always bad avi or mpg to be the fault for me.
Ignore this, complete rubbish. Depends on the burner. I have both pioneer A06 and Sony DRU-500 and they both burn princos at 4X no probs.Originally Posted by fsured
I have no trouble writing to Princo media either.
Getting the buggers to read past the 3.5 - 4Gb mark is another matter. Don't forget writing to the disc is only half the story - if the damn things won't read, they're coasters no matter what speed you wrote them at.
I would guess 2/3rds of the Princo media I have used have been iffy on the edge. Which is a shame, their type 8 CD-R's are the mutt's nuts and play properly in Sony DVD players...
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
Why does the disc speed matter with the burning?
By coody in forum DVD RippingReplies: 20Last Post: 31st Jan 2008, 18:39 -
the best burning speed for DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 13Last Post: 15th Jan 2008, 08:50 -
what is a good burning speed???
By offensekilla in forum Authoring (DVD)Replies: 6Last Post: 29th Aug 2007, 01:08 -
dvd burning speed
By nobbyiscool in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2007, 07:54
