  1. I'm having serious problems understanding CCE and have searched for an hour with no helpful results.
    With TMPGEnc, If I have file.avi and file.srt in the same directory, the subtitles are burned onto the final video when the avi is turned into .m2v
    Is there a way to do this with CCE? CCE is much faster at converting my video and I'd hope that adding subtitles wouldn't change that by much. But what exactly do I have to do, as I don't see any option in the program for subtitles?
  2. Gah, I'm going crazy because nothing is working.
    I have an avi and an srt, and I want to encode with CCE.
    # -= AviSynth script by FitCD v1.1.2 =-
    LoadPlugin("c:\......\textsub.vdf")
    AviSource("C:\WINDOWS\Desktop\xxx.avi")
    BicubicResize(320,384,0,0.6,4,0,712,480)
    AddBorders(16,48,16,48)
    TextSub("C:\WINDOWS\Desktop\xxx.srt")
    ConvertToYUY2()
    This gives me an error when I try moving the .avs to CCE. It works if I get rid of the LoadPlugin step.
    LoadPlugin("C:\WINDOWS\SYSTEM\vobsub.dll")
    vobsub("C:\WINDOWS\Desktop\xxx.sub")
    ConvertToYUY2()
    This one works if I get rid of both LoadPlugin and vobsub. Either way, I'm not able to incorporate subtitles. I did get a video once, and I'm assuming that was in the first scenario, with the LoadPlugin turned off. Apparently, the TextSub step still worked somehow. However, I then moved the file to DVDLab (which ran pulldown), and the subs were large and stretched vertically. Could this also have to do with me making a Half-D1 DVD?
  3. I'm a Super Moderator johns0's Avatar
    canada
    You can try dvd2svcd with cce,it lets you insert subs and does with correct letter size and color and language.
  4. Where can I add subtitles in DVD2SVCD? The only way I see is by adding AviSynth code. I tried doing that again and when it got to the encoding step, CCE messed up again (The .avs loaded as a 10 second, 240 frame thing, or something along those lines)
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    R U sure you're using the right textsub.vdf?
    I use the one in my VobSub dir:
    LoadPlugin("C:\Program\VobSub\textsub.vdf")
    textsub("c:\y\xyz.ssa")
    /Mats
  6. I'm a Super Moderator johns0's Avatar
    canada
    In dvd2svcd click on the subtitles tab and check rip subtitles,then load the file and in the dropdown box beside the file name choose add external subtitle stream.
  7. I tried using the textsub.vdf in my VobSub folder and got the same error.
    I have, however, got subtitles to load in DVD2SVCD. Kinda.
    My .srt files have tags like [i], but the app that DVD2SVCD uses keeps the italic opening and closing tags when making bmps of the subtitles. Is there any way to keep the italics, or do I have to ditch them?
  8. Actually, I'd like VobSub to do the subtitling. I know HOW to have that work now, but I can't get it TO work. As stated above, I get an error when I try loading vobsub.dll, even though the file is there and I'm pointing to it correctly. Why doesn't it want to LoadPlugin textsub.vdf or vobsub.dll?
    LoadPlugin("C:\WINDOWS\SYSTEM\VOBSUB.DLL")
    Whenever I include this line, the error I get in CCE SP is:
    "Frame size 740x56 is not supported. Supported frame size is up to 720x576"
    and then the .avs doesn't load. If I get rid of the line, no problem.
    Edit: Loading the .avs into media player brings up:
    "Plugin C:\Windows\System\Vobsub.dll is not an AviSynth 2.5 plugin. (blahblah.avs, line3)"
