Are there any experience playing MPEG2 File with
higher resolution then 704x576?
Regards
No one's posted on doing anything like this before...
Even if they did though, it is unlikely that it will work (even DVD streams are only 720x576/480 ).
And, even if it did work, there would be no point (your TV does not have the resolution of displaying this extra detail -- most TVs won't even show DVDs at their full glory).
Regards.
Michael Tam
w: Morsels of Evidence -
I know the restrictions for the TV, but if I play the
File using a PC and a Beamer with 1024x768.... or greater?
I have some material with a higher resolution (rendered video and Photos which I will put together, also 3 Videostreams with a resolution as high as possible in different parts on the screen...)
Any ideas? -
Yes, I've done it. Your post doesn't really have a definitive question though.
Anything other than 480x480 doesn't work on my Pioneer DV343 but plays fine on computer.
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 19:29 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 06:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 10:46 -
Why is my movie not DVD compliant?
By johnharlin in forum Video ConversionReplies: 19Last Post: 3rd Jan 2008, 21:11 -
HDMI compliant?
By vanjo in forum DVB / IPTVReplies: 6Last Post: 16th Oct 2007, 20:47
