Can somebody tell me a couple of the best text to speech software out there..... especially the ones that let u output .wav and .mp3 for editing......
SayIt from Analogx.com is a freeware, it's okay.
there was one that used to come with SoundBlaster cards called DrSBaitso, you might be able to find it somewhere.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
go to www.webattack.com and check out the text to speech part under freeware. I used one and it is really good. TTS has come ALONG way since I got into the TELCOM biz.
DAVE - DAVE , WHAT ARE YOU DOING ?
WWW.READPLEASE.COM
or if you're on a MAC
Control Panels>Speakable Items
Will you stop? DAVE -
isn't that speech to text , not text to speechOriginally Posted by mol3000"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
SubTitle Creation with Speech to Text
By zenzen1 in forum Authoring (DVD)Replies: 7Last Post: 4th Nov 2014, 06:53 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 09:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 11:38 -
Change a Text to Speech GPS into a I-pod Touch look alike
By SingSing in forum Portable VideoReplies: 1Last Post: 6th Apr 2008, 08:28 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 16:50
