  1. i made a mistake setting source aspect ratio to 1:1 vga instead of 4:3
    i captured at 720x480 and intend to burn to dvd to watch on my tv...will this be a problem? cos i already deleted the source file....
  2. Member adam's Avatar
    Sep 2000
    No its not a problem at all. 1:1 just means it essentially uses whatever the aspect ratio of the source is. This is commonly used on avi files since many codecs which use the avi container don't support aspect ratio flags.
    If the source you captured was displayed as 4:3, and you used 1:1 source aspect ratio in TMPGenc, then your output file will also be 4:3.
