Hi, can anyone recommend software that will allow me to re-author my DVD-VR discs (i.e., DVD recorded on to my Philips DVD recorder using DVD+RW discs) All I want to do is change the look of the menu, make the menu a motion menu with some sound. I am looking for a "simple" software solution and one that will support AC3 sound (my recoder records in AC3 sound format)
Also, is there any software that will allow me to do the above but also add additional .vob files to the DVD-VR disc. For example, if I have a movie on my DVD-VR disc but have loads of space left, I would like to add .vob trailers or music .vobs. But I don't want to use loads of software that takes hours and is simply not worth the hastle.
At the end of it all, I just want to keep my original movie but personalise the menu - make it look professional and maybe and additional .vob files to fill the free disc space.
If anyone knows of such software, I'll eat my shoes. I have been looking 4 months and not one software programme can do all. They either do not accept AC3 sound, or want to re-encode everything, or don't allow moving menus etc. Help would be appreciated. Thanks.
Results 1 to 1 of 1
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
Authoring Bluray with DVD discs
By carlmart in forum Authoring (Blu-ray)Replies: 10Last Post: 16th Oct 2010, 07:20 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29
