I have the ati tv wonder pro. Ive been playin around for a couple weeks and have givin up hope unless someone can help. First off mmc wont work for the tv. Never has. Both the software that came with the card and the latest from ati. Always same error, cant intialize video, then press ok to run tests and it says i have no direct x, no wdm, or inf files for this card. So i found windvr works for tv, thats good. But i have yet to find any software that will let me capture higher than 320x240. Not that I cant with the software, they wont. Always some error along the lines of failed to capture. Im talkin vdub,ulead,pinnacle,roxio,virtual vcr. Cant do it with tv shows nor the analog stuff from my hi-8 which is what i want to do the most. So is this normal,or am I missing something, or is this card a peice of crap. Im new at this captureing bussiness, and im not having fun so far.So if someone knows anything can ya help me out. Thx in advance. If ya need more info just yell 8)
nope, im thinkin takin it back to xchange for another or sumthin different altogether
sounds like some kind of installation issue. Or drivers maybe? Have you tried this driver? btwincap.sourceforge.net
I think lordsmurf is big into ATI cards. You may want to check his site out....
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 20:00 -
how to capture in very high quality in VirtualDubMod?
By ayyak in forum Capturing and VCRReplies: 5Last Post: 5th Jan 2009, 02:41 -
What is need to capture and edit High Def Video ?
By beammeup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 7th Jul 2008, 09:11 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 15:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 11:20
