I have a panny E-30 and I can't believe I haven't noticed this before.
I popped in the ANTZ videotape (VCR is hooked directly to the DVDRecorder) and noticed that the colour of the ants is constantly fluctuating. They'll appear slightly orange, then slightly red, then slightly orange all within the span of a couple of seconds. And it doesn't stop.
I know it is the Recorder and not a combination of Cables/power source/VCR problems (unplugged and switched everything - Including a New VCR), because when I unplug the composite video cable connecting the VCR to the DVDRecorder and plug it directly into the TV, THE COLOURS LOOK FINE - NO FLUCTUATION!!?!!
I have turned the 3D Y/C on/off and it makes no difference.
I don't think that the Machine is malfunctioning, because when I record my satellite dish thru the S-Video input, it looks fine.
Is there a way to disable the TBC ?(which I'm assuming is causing this)
Would buying a composite to S-Video adapter help bypass the TBC circuit?
Your input is much appreciated.
The problem is not macrovision based. That problem would go light-dark-light-dark. And only if you try and record the source.
I am not recording the source, I am just playing it through my E-30.
If I tried to record it, I get the message "This material cannot be recorded", which I understand, seeing as it is copywrited material.
Recording ANTZ is not what I'm trying to accomplish, I'm trying to find out why the colour fluctuates. -
ScottyMac,
I noticed a very similar problem this morning with The Birds on VHS. Play the tape and view it directly on the televison and there are no problems. Hooked up the VCR to my CyberHome DVDR and there was a subtle but noticable color fluctuation; color went from fine to banded. The CyberHome didn't notice any copy protection ... it recorded the video without stopping.
When I placed "The Video Clarifier" in the video path the color fluctuations went away.
I am curious, did you find a way to disable your TBC?
Hope this helps.
Originally Posted by scottymac -
Originally Posted by CodeDawg2K
Plus the macrovision nag is gone too.
Cheers.
No component or composite inputs on new hdtv
By gt0guy in forum Newbie / General discussionsReplies: 3Last Post: 28th Nov 2010, 05:25 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
Canopus AceDVio composite capture problem (Svid works, but not composite)
By bfrandse in forum Capturing and VCRReplies: 3Last Post: 28th Oct 2008, 10:55 -
HP m7760n video inputs ~ how do I get these inputs to work?
By FTLOSM in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2007, 19:19 -
Black bars fluctuating...
By FallenAngelII in forum Newbie / General discussionsReplies: 5Last Post: 16th May 2007, 14:04
