I have a really old VHS tape which I want to caputre however there is alot of static, and popping in the sound. If I capture the video is there any way to remove the static and popping later?
yeah, with some work..
goldwave has a couple of good filters in it. One is called hiss/click remover, one is a noise reduction filter.
There are loads of other software out there that can do the same things, Adobe Audition is a good one. -
I found that soundforge noise reduction has a nice click and crackle remover plugin as well as a vinyl plugin too that works wonders.
"Knowledge makes a man unfit to be a slave."
Frederick Douglass
Annoying popping sound after converting AVI to DVD
By Smudge249 in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 16:24 -
I need to remove sound from footage.
By Lensmeister in forum Newbie / General discussionsReplies: 10Last Post: 7th May 2009, 01:28 -
XBOX 360 HD-DVD sound popping when HD-DVD starts only with HDMI hookup
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2009, 20:03 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 10:46 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 13:54
