I purchesed a 25 count spindle of the best buy tdk dvd+r. Dvdinfo pro states "Manufacturer ID cannot be read". My Memorex dvd+rw can be id. My drive is a NEC ND 1300a. any ideas![]()
Results 1 to 9 of 9
GuestGuest
just means it can not be read ... as in there may not be any on there ..
this media has no code and seems to be alright (i never tried it) https://www.videohelp.com/dvdmedia.php?selectmedia=530#comments
I had the same problem with my 1300a. You have to burn something to it first and then check the media code. It will come up then.
Yea burn info on the disk and then do a info read out on the media.
Good Luck!*New Mac user*, been PC user 4 life -
Yep....some media(at least for me anyway) will not give you a media code until there is data on it. Some of my Philips discs are this way.
Yup, my philips +r media is like this, along with most other kinds of +r media on my 1300A.
who is the manufacturer of avant ht-ts500?
By alandica in forum Newbie / General discussionsReplies: 4Last Post: 7th Dec 2011, 10:07 -
who's the best hdd manufacturer ?
By joecass in forum Newbie / General discussionsReplies: 33Last Post: 28th Jan 2011, 16:58 -
3 Digit manufacturer's code for Toshiba SD-V395KC
By Snakebyte1 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 10:15 -
which online media store(s) shows Manufacturer ID ?
By archaeo in forum MediaReplies: 6Last Post: 5th Jan 2008, 19:35 -
What's my DVD's firmware manufacturer?
By b00h in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Dec 2007, 14:47
