  1. I've been trying to convert few mpg files into divx with VirtualDub.
    But they're having problems with incomplete frames. So the conversion processes terminate in the middle.
    Is there any tool to fix incomplete frame?
    One is found with no frame 0?
    Can anything be done with this sort of problem?
  2. perhaps try to frameserv the video with avisynth. Often when Vdub wont liek an avi I can get by with avisynth. If avisource fails for you, try directshowsource instead.
  3. urh... I was trying to convert a mpg into avi, not the other way around.
  4. I know what you want to do. I am sugesting trying using avisynth to frameserv the video into vdub. If it's mpeg1 you can use nics mpegsource , or you can use directshowsource. If there really is a bad frame directshowsource will probbaly have the most luck at getting through it al in one piece.
