i did a search couldnt find this, im trying to convert an avi using tmpge........it gives me "this program has performed an illegal operation and will be shutdwon" error i messed with the settings in environmental to no avail, i checked the avi with divfix and it said it has no errors.....has anyone ever seen this?
it means it has detected you are trying to convert a downloaded screener ..
you know the special ID tags that are now embedded..
:P :P :P"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
im sry i dont know what a downloaded screener is.....could you elaborate a little?
i allready read that man, i see nothing that has to do with the error i got, i guess typing and talking to somone is too much , thanks anyways
it would have helped to post the error report - as it could be any number of things and no one can answer without a little more info ...
The requested operation requires elevation. WHAT!?
By Hikari112 in forum ComputerReplies: 16Last Post: 2nd Feb 2018, 05:08 -
Massive conversion operation
By NickPapageorgio in forum Video ConversionReplies: 1Last Post: 28th Jun 2011, 14:36 -
AG-1970 operation question
By jcolegrove in forum RestorationReplies: 3Last Post: 12th Apr 2010, 11:35 -
ConvertX2DVD shutdown
By smalld in forum Newbie / General discussionsReplies: 2Last Post: 27th Nov 2007, 20:27 -
Automatic Shutdown
By borisblavasky in forum ComputerReplies: 10Last Post: 12th Jun 2007, 14:13
