I'm using DVDShrink 3.1 and I'm having audio problems. I had the same problems with the previous version as well. The audio only plays on 1 channel (1 speaker or 1 side of my home theater system), does anyone know if this is normal or am I just doing something wrong? I have a Lite-On 411S DVD+RW/-RW
I have the same problem...audio from 1 channel only. I'm using DVDShrink/Nero 6/Sony DRX-510UL.
Hi you two.
My guess would be you're doing something wrong, as DVD Shrink does not "mess" with the audio streams.
Could you give us more details as to what audio streams you keep/delete, and what your TV/home cinema system is able to normally play (AC3 5.1, DTS,...)? -
ddlooping,
My home system plays the normal 5.1 but I don't mess with the audio when using DVD Shrink...the only audios I took off would be the Spanish & Director's comm.
Oh...and somehow, the preview window with Shrink 3.1 won't work but the older version works fine on my system. Please help.
Thanks.
Byron
AutoGK - ripping the DVD gets out audio out of sync - okay after DVDShrink
By lchiu7 in forum DVD RippingReplies: 7Last Post: 7th Dec 2009, 23:06 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Problems Burning Discs with DVDshrink/Nero
By iownju in forum DVD RippingReplies: 5Last Post: 20th Jul 2008, 15:56 -
Still Having DVDshrink Problems
By malleus in forum Newbie / General discussionsReplies: 1Last Post: 11th Oct 2007, 15:55 -
DVDShrink - Multiple audio tracks? What's what?
By kelemvor in forum DVD RippingReplies: 17Last Post: 16th Jul 2007, 11:07
