  1. Once a DVD Image is made on your hard drive, if you notice a wrong thumbnail in a chapter on the main Menu, is there anyway to modify it without going through the whole 6 hour rendering and encoding of the original project? I use Pinnacle Studio 8 but also have Sonic's My DVD.
  2. you'll need to re-author. it won't be good idea to encode it again, make sure the authoring app doesn't encode it again.
  3. Hmm... If you did not deleted Auxilary Files you might going to be able to get mpeg files and reauthor them (recreate menu) in PS8. If not, you might be able to extract mpeg files from DVD like from commercial DVD and re-author them with PS8. Do I make sense ?
