hi
i have Quicktime 6.03 and when i try to open a .mov file
i get the following error
XXXXXX.mov: QuickTimePlayer.exe - No Disk
"there is no disk in the drive. Please insert a disk into drive F:"
and i cant open the movie, or do pretty much anything
i've change to version 6.05 but i get the same error
any ideas?
thanks
Increase knowledge, increase sorrow.
Did yo put a disk in the Drive?? Just kidding. Change the shortcut path to wherever the file is on the HD. If not you've got a corrupt file
no luck
the file isent corrupted it happens periodically with any file..
Increase knowledge, increase sorrow. -
You should have said that in the first place. You're drive might be taking a dump. try the disk in another computer.Originally Posted by stk
nonono
i dont have the fine in any disk, i have it in my computer, when i double click it, appear the message
i read that its quicktime error but nobody knows who to ged rid of it
yes
its fixed
all you have to do is delete qttask.exe from your qicktime folder
cheers
-StKIncrease knowledge, increase sorrow.
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 09:31 -
using insnav.exe
By nighthawk2018 in forum Newbie / General discussionsReplies: 0Last Post: 31st Dec 2009, 06:10 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
has anyone got the old 2.1 .exe file
By NIPPERLOCKO in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 27th Oct 2007, 12:35 -
bgsvcgen.exe?
By alegator in forum ComputerReplies: 11Last Post: 16th Jul 2007, 12:06
