Can anyone help ? I am converting some Real Media video files (.rm) to .avi files, but I'm having a few issues. I am using the TINRA GUI application and can convert the files. However when I play them as .avi files in media player I just get sound and no pictures.
I have tried changing the compression rates, I ususally use uncompressed and different versions of real player but no success.
Can anyone suggest anything ?
Thanks,
I'd suggest you not bother. RM files are variable frame rate. AVI can't do variable frame rate. That's part of the reason you're having audio problems. Maybe somebody else knows a better way than TINRA.
Converting DVDs to .avi files
By c_woodul in forum Video ConversionReplies: 7Last Post: 28th Nov 2011, 14:05 -
Converting .vob files to AVI
By abrathet in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 21:43 -
Converting mp4 files to avi files
By HartsVideo in forum AudioReplies: 1Last Post: 18th Jul 2008, 19:20 -
Converting then burning AVI files
By Tbag in forum Authoring (DVD)Replies: 5Last Post: 7th Jun 2008, 17:24 -
Converting AVI files to Video_TS files/ffmpegx V0.0.9Y OS is Tiger.
By sadepussycat in forum MacReplies: 10Last Post: 2nd Jun 2008, 16:43
