I have DVD X Copy Xpress, and theres nothing in the options to say that i can rip faster. the ripping process takes FOREVER. Is there a way i can make it faster?
if you are using your burner to rip it will take forever, invest in a seperate dvd reader like the Lite On at Walmart for $40. Also show some specs for your sysem as well as operating system for us to help you further.
i just installed a lite on combo drive--48/24/48/16. i have a P4, 2.4gig, 1gig mem, intel 850 mobo. it ripps no faster than it did when i use the dvd burner. how can i make it faster??
thanks--dave -
i have a NEC 16x dvd-rom drive and i'm ripping an entire dvd in less that 15 minutes... i've read that making sure that the drive that is doing the ripping, works faster if it's set as the "master" instead of "slave" on the ide cable.
that's the way i have mine setup... don't know if that would help you guys or not...
there is also a post on this forum that takes about this:
https://www.videohelp.com/forum/viewtopic.php?t=187112 -
I have a NEC 4x dvd burner, the read spead is supposed to be 12x. But using DVD decrypter it starts out around 2x then slowly it increases speed till it hits 4x. I have a 3.2Ghz P4 with 2x80GB SATA HDD in RAID 0. It takes like 30 minutes for it to copy a full dvd. My dvd burner is on IDE and my hard drives are on a different controller.
Can i not rip faster than this? -
NEC burners are not popular where I'm at so I have not had the chance to test one, but some brands are locked at a certain ripping speed and can be unlocked for a faster response - same goes for some DVD readers as well!
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 08:30 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
Do newer drives rip dual layer discs any faster?
By Sephiroth666 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Feb 2008, 09:40 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 20:28 -
How to burn faster
By Finfarin in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2007, 18:19
