  1. I have the original AVI file that I pulled down from my camcorder, which is 10gb in size. I converted it with TMPGENC via the guides on this site to the DVD MPEG2 format. The new MPEG file is approximately 1.6gb in size.
    When I play the new MPEG file on my computer the video seems "CHOPPIER" then the original AVI file. It just doesn't flow as 'smooth' as it should. I mean the original AVI is real video, and moves very nice, the motions of the people are fluid, etc. But on the new encoding they seem a little 'choppier.' Also, when i do burn it to a dVD and play it in a DVD player, when there is motion the entire picture gets super BLOCKY and such, but in still shots its pretty high quality.
    System Specs:
    Pentium 4, 2.4ghz
    768mb RDRAM PC1066
    Hard Drive space 8gb/80gb
    GeForce 4, MX 420 Video Card
    Windows XP SP1 with all current patches/updates.
  2. Can someone please help me? When I burn the video and play it in my DVD players the video gets really BLOCKY and such whenever the camera pans/moves.
    Perhaps I did something wrong when encoding it? I followed the provided instructions in the guides.
    Thanks!
  3. Member daamon's Avatar
    Melbourne, Oz
    Hi SirMack,
    These two links:
    http://dvd-hq.info/Compression.htmland
    http://www.lordsmurf.com/convert/tmpgenc/tmpgencplus.htm
    ...both provide good details on the settings in TMPGEnc. The first is specifically for DVD compliant MPEG2, with the second being for MPEG1 & 2.
    I hope they help, or are at least of interest.
    In the meantime, post what settings you used in TMPGEnc - These will be useful in identifying any problems there.
    Post back on how you got on...
    EDIT - I've seen this in a topice before, and found it. I didn't have the time to read it, but it might be of use:
    https://www.videohelp.com/forum/viewtopic.php?p=724194#724194
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
