I'm posting this Q on behalf of a friend - he's at his wits end and is waiting for his acc to be created here.
I am trying to back up a disc using PINNACLE instant copy,
the disc plays fine in all of my players, but when I try to copy it it gets to 44% then stops and tells me "Access violation at address 10003b00 in module 'vobsrc.ax' read of address 0000000"
Have tried decrypting the disc and copying it to my hard drive and then
burning it, but I get errors on all!
Can anyone shed some light?
I have pointed this out a couple of times that Instant Copy does not author properly. There is some of of mismatch between the ifo files and bup files. i have tried to rip back ups that are made by IC by other software, such as DVD Decryptor, SmartRipper, DVD Shrink, DVD2One, or DVD ToolBox. None of them can do it.
The only way you can made a second backup from the first backup is to use Instant Copy itself. -
PS - Even if you copy the files on the back up disk to the hard dive by using Windows Explorer, when it comes to burning those files with Nero, or RecordNow, it failed in the their DVD compatibility tests and you can't burn them properly. The only way is to use IC again and make a second backup.
Mirror copy of Pinnacle DVD
By Straightlegger in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 11:40 -
Pinnacle Studio 12 frame rate error for Panasonic AVCHD Lite mts files
By dewispew in forum EditingReplies: 10Last Post: 13th Jul 2009, 02:13 -
Phillips 3576H - copy protection error when recording from TV
By robjv1 in forum Newbie / General discussionsReplies: 2Last Post: 8th Mar 2009, 15:30 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 22:29 -
Error I get after I finish copying a dvd with copytodvd
By litzg5 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2008, 14:17
