I'm trying to get AVI's to work in TMPGnc or VDub. I get different errors in both apps. I think I have the codex's and i've even installed the binaries just incase.. but still I'm unable to open them.
Firstly can someone clarify the diff between TMPGnc and Vdub. As they seem to both work and not work on the same files.
The clips I'm working on play very well on the pc and are clear and sharp.
opening the clip in TMPGnc I get an error that reads..
"Cannot open or unsupported" yea, ok, but why?
I'll put out the GSpot info first and see if I can get the error screen shots as well
this is the VDubb error
Get the 4cc changer and change the headers to divx/divx. the header div3 doesn't have a registered codec on your sustem. Other people will tell you to install the DivX3 codec, but it breaks a lot of things in doing so (it needs to be the first thing you install).
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Thanks for that.
what options should I use??
Woops DVX to DVX ????
i'll give it a go. -
Thanks Andy, So I need yet another codec? DIVX5.1 Pro
Is this yet another geeky thing that will take me a life time to understand and run or can I just point and click.
If this is another wild goose chase I'd rather not bother.
So where do I get this codec?
thanks. -
Well I went to the link posted here. Ran the installer for the software as suggested and then attempted to open the rouge file in TMPGnc and it worked.
I'm now running the app in the background as I type this message.
Going nuts trying to convert a video
By ehunter in forum Video ConversionReplies: 38Last Post: 19th Mar 2010, 10:50 -
Soo confused
By slaak in forum Newbie / General discussionsReplies: 9Last Post: 10th Aug 2009, 20:44 -
Printer driving me nuts
By bryankendall in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2008, 09:47 -
This cdex is driving me NUTS!
By Jo The Veteran in forum AudioReplies: 4Last Post: 18th Oct 2008, 09:26 -
computer going nuts
By jyeh74 in forum Newbie / General discussionsReplies: 33Last Post: 11th Jul 2008, 21:18
