Ok, I have an Athlon T-Bird (SDR) 1.GHz CPU at 100MHz Bus...and noticed that the mobo is capable of 133MHz Bus. Is there an SDR Athlon T-Bird capable of using the 133 Bus? (Wouldn't mind getting full use of the 256MB PC133 RAM I threw in.)
Results 1 to 15 of 15
If it's a VIA KT133 chipset the answer is NO. It doesn't support 133 Mhz FSB but it support 133 Mhz SDR RAM. Only the KT133A chipset supports 133 Mhz FSB & SDR RAM. (SDR= single data rate).
In order to utilize the 133MHz FSB, you also need a version "C" Athlon (and the other stuff mentioned above).
I seriously doubt it's a VIA KT133...I'm not sure what brand it is, but the only jumper on it is one for adjusting between 100MHz and 133MHz, it's MicroATX, and surprisingly (for how cheap this Compaq was) it has AGP.
The switch on my EPOX motherboard for 100/133 changed the ram and CPU speed. I use the 133 ram and 266 bus thunderbird.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
nope....just a mobo with a multiplier selection and a #2 pencil.... -
You need to change the multiplyer from 10x to 7.5x when going from 100 to 133, or else you will hit 1333 mhz and I do not think your CPU will run at this speed
there isn't a multiplier jumper unfortunately (at least i couldn't find one), only the bus speed jumper
Well, there should be multiplier settings in the CMOS, man... How many years has it been since they eliminated real jumpers for CMOS settings? The last two motherboards I have had do not have like any jumpers... everything is done from the BIOS.
irc.webmaster.com port 6667 #DDR -
jmiller the "VIA VT82C686A" is the south bridge and yes it part of the KT133 chipset. That chipset only works to about 110 Mhz. Via build into that chipset approx 10% headroom.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
Quick AVIdemux question!
By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 01:19 -
Quick question on DGIndex
By dimtim in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2008, 20:28 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
