I looked up my dvd player on this site for info on what it can do. I have a JVC xv-523. I looked at the posts and half the people claim to be able to play vcd's "no problem" and another half have the same trouble i have. The time clock runs but there is no video or sound. I used TMPGEnc and followed the guides for creating a vcd... does the program i use to write the cd matter. I use Adaptec Easy CD Creator. Another person on the post used the same program and had the same problem. Maybe its related? any help would be awesome. thanks
are you encodeing vcd or svcd? what bitrate are you useing? i had the same problem with my Apex and i realized my encoding bitrate was WAY too high. that fixed my problem at least with vcd's. i still have yet to get a svcd to play on it. i still have the same problems with that....
i just left the bitrate as it was when i tried it...should i use a bitrate calculator.... for the file im testing out this is the information on it MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 192kbps
How did you burn your encoded MPEG? If it was w/ Nero that could be the problem. Instead use VCDImager (this is a command line program so I would acually use VCDImager Easy, click to the left on Author) to make an image of your MPEG, and then burn that.
Under author you can find a link that will allow you to d/load VCDImager, VCDImager Easy, and CDRDAO. So you can load your MPEG -> make bin/cue -> burn in one step. -
dude...you are a god amongst men haha yeah...it worked...thanks bro it was the program i was using to burn the cd the whole time. this worked great.
<font size=-1>[ This Message was edited by: suchadork00 on 2001-10-19 03:24:09 ]</font>
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 07:42 -
For VOB files to AVI, I use avi.net . . Question
By nhbfan12345 in forum DVD RippingReplies: 4Last Post: 11th Sep 2008, 00:02 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 20:14 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
