Salut!
I'm having some trouble with my VCD conversions. Actually, a lot of trouble. And since I couldn't solve my problem, I was wondering if you guys could recommend me another AVI to VCD convertion program. Maybe changing the conversion software I an solve that.
I'm looking for a good converter, and, like the topic says, as good as TMPGEnc, cause I've found some softwares here that don't have all those TMPGEnc options. I won't something less limitaded.
Thank you guys, be seen ya.
Results 1 to 9 of 9
redwudz, Does VCDEAsy makes encoding stuff? How? I have it here, but I didn't know about that... any tips?
You said mainconcept? I'll take a look.
Another question: Can codecs cause encoding trouble? I'm experimenting some freezing when I play the VCDs I've made on my Standalone Player. -
keckrodrigues,
With the limited information that you have provided it is difficult to point you in the right direction. TMPGenC is not difficult to use and IMHO is one of the best encoders out there. Of course, there are others and their fans as well.
Maybe a few more details about what is going on or what errors you are getting or problems encountered will help others highlight a different path for you.
Ed -
VCDEasy is not an encoder. It's for creating/burning/ripping (S)VCD images, assuming you already have a (S)VCD compliant mpeg.
Canopus Procoder is another encoder you can try. What kind of problems are you having with TMPEGenc? You should probably try to resolve the issues you are having and stick with it. There are lots of people here that would be willing to help. -
Ok guys ... sorry about the few information I gave you.
My problem is: every video I have encoded, frezees on my standalone. But it's not a problem of my player: some .mpg ready to burn I've downloaded and burned, works pretty well. No freezing at all.
I thougth it was all about the encoding program (TMPG). But I also tried that YUMPG thing, and same problem.
My doubt is: can it have something to do with codecs? My computer hardware configuration? Operational System?
I would really aprecciate if anyone could give me any tip about this hole situation. Thank you all!
try a program called dvd2svcd it is a software suite that pretty much does all the settings for you. there is an option to change the input video to use avi files. it can use tmpgenc or cinema craft encoder and it will handel all the settings for you. you can use this to make vcd or svcd. hope this helps
Donadagohvi (Cherokee for "Until we meet again") -
I am specifically having trouble with VCDs ... SVCDs seens to work fine at my player.
I'm using as source downloaded avi files from web.
In Tmpeg i followed the template, and still got thew problem.
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
I use TMpgEnc to convert MOV to DIVX. But the quality of AVI isn't good
By natong in forum Video ConversionReplies: 0Last Post: 11th Apr 2009, 01:21 -
What are good specs for a high-quality MP4 file? (Will look good on my 40&q
By HarlanPepper in forum Video ConversionReplies: 6Last Post: 11th Feb 2009, 04:18 -
Looking for some good instrumental music that would be good for football.
By ingeborgdot in forum AudioReplies: 8Last Post: 26th Nov 2007, 22:18 -
TMPGEnc not working.. what else is good for avi to mpg?
By andre477 in forum Video ConversionReplies: 10Last Post: 21st May 2007, 02:52
