This is my enviroment:
Pioneer 106, blank DVD+R ricoh 4X certified, IC8, DVDdecrypt, Nero, Alcohl120%.
Instant Copy 8 at the end of the process produces an image with PDI extension.
This image may be, obviousily, burned with IC8 but yhe burning speed is always 4X also if you put medium or minimum in the option of burning speed.
So i did tried with Dvddecrypt (last version); this program recognizes also the speed available with the combination of burner and blank disk; in my case 2,4x & 4X. BUT Also this program burns always at 4X; also if i put 2,4X value in the box.
Nero don't recognize PDI file.
The only way seems to be to transform PDI file in ISO with some tools but this requires another cicle of reading and writing not good for HD..
Someone have a solution???
Problem solved myself.
If anyone interested:
It is necessary to change in DVDdecrypt driver in "option" "general"; by default the program use Win default driver; if you change with Elby proprietary one I will be able to burn at correct speed that you have configured instead of maximum value 4X.
Bye
cant copy speed racer
By tichami in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 10:26 -
Burning speed vs. disc speed
By coody in forum DVD RippingReplies: 5Last Post: 26th May 2008, 02:41 -
the best burning speed for DVDs
By JohnnyBob in forum Newbie / General discussionsReplies: 13Last Post: 15th Jan 2008, 08:50 -
what is a good burning speed???
By offensekilla in forum Authoring (DVD)Replies: 6Last Post: 29th Aug 2007, 01:08 -
Burner Slowdown
By Mitchum22 in forum DVD & Blu-ray WritersReplies: 13Last Post: 28th Jul 2007, 00:01
