I have searched the internet extensively for a way to import .vob files from DVD-R into Final Cut Pro 3. Is it possible without purchasing a lot of software?
You have to convert the video to DV. You can do that for free with DiVA. Thats the easy part. Getting audio to sync with it (if your source is an NTSC DVD) will cause you headaches beyond belief.
Thanks a million. Fortunately my .vob file is PAL and the sound isn't very important as most of it - if not all - will be replaced in Final Cut Pro 3 anyway.
Hauppauge PVR footage won't import into FCP
By blacklevel in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 10:25 -
Import AVCHD with 5.1 Sound in FCP
By Mr.Ash in forum MacReplies: 11Last Post: 3rd Jul 2010, 12:01 -
canon's 24 import into fcp help!
By kmk802 in forum MacReplies: 0Last Post: 15th Sep 2009, 23:32 -
FCP: What is the best way to work with .m2v files in a FCP timeline?
By murraymile in forum MacReplies: 1Last Post: 23rd Jan 2009, 15:59 -
Home vid Vob files won't import
By JackT in forum DVD RippingReplies: 5Last Post: 8th Jan 2008, 00:29
