Results 1 to 11 of 11
    Portland OR/Hita Japan
    Im going to trry to make my first cocoa program. It will be basic. It will be a small GUI to mux Matroska Files. I should have it online by this weekend.
    Q
    "Good Luck 007"
    In Memory of Desmond Llewelyn
    and it isnt coming........im srry.......the program isnt working correctly. I am wondering why it isnt. Its odd. if someone wants the binaries, IM me at Qshartle
    Q
    "Good Luck 007"
  3. Member Thargok's Avatar
    Nov 2001
    do the binaries work?
    binaries work perfectly. Ive made about 20 mkv's. You need to use VPC to get the subs and stuff from your vob. My next goal is getting ogmtools to work.
    "Good Luck 007"
  5. Member Thargok's Avatar
    Nov 2001
    OGM tools has already been compiled. Go ahead and give me the binaries, they should be pretty simple to make a GUI for (of some sort)
  6. Any news on this? I'm anxious to try out .mkv or .ogm on my Mac.
    Umm.........did you read the full post? Its been stopped. For some reason, the binaries wont work with cocoa.
    Q
    Plus no player on mac supports vobsub anymore.
    "Good Luck 007"
  8. Originally Posted by qshartle
    Q
    Yeah, I did. Seemed a tad open ended, with someone asking for Ogmtools so they could make a GUI front end.
    OMGtools, was never a gui. If you read closely, it says they have been ported. But not GUI'd.
    Q
    "Good Luck 007"
  10. Originally Posted by qshartle
    Q
    Thargok said: "OGM tools has already been compiled. Go ahead and give me the binaries, they should be pretty simple to make a GUI for (of some sort)". I'm wondering if that GUI was ever made. I can't make heads or tails of the command line version.
    lol, look at the manpage.
    Q
    "Good Luck 007"
