What tool do you guys recommend for removing popping/crackling noises from an AC3 file??
On a somewhat related issue, I created my AC3 file using DVD2AVI. Anything I can do with DVD2AVI to not get the popping and crackling?? The original VOB file doesn't have the noise.
Originally Posted by huntingtheasphyx
- Audio->Output Method->Demux(AC3, MPA, DTS)
- Dynamic Range Control is default (normal)
- Dolby Surround Downmix is selected (but have unselected it with the same result)
- 48->44.1kHz is OFF since I'm eventually putting this on DVD
Thanks for any help! -
It could be the .AC3 codec that you have on your computer. DVD2AVI doesn't do anything except demux the file from you VOBs (with your settings).
If you are listening to the audio and it pops, back up a few seconds to see if it pops again in the same place. Onboard audio "cards" also will pop once in a while.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Originally Posted by SLK001
What AC3 codec do you suggest I install??
AC3 audio editor.
By reboot in forum AudioReplies: 72Last Post: 8th Jun 2017, 11:51 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
