  1. I have a MiniDV cassette recorded. I would like to make DVD of it. What software I need? Could you tell me the steps. I have sony trv33.
    thanks
  2. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    Nobody likes a bunch of yackity-yack.
    Monroe, Mi
    plenty of guides to the left
  4. Pinnacle Studio version 9
  5. Member daamon's Avatar
    Melbourne, Oz
    Hi techno123,
    See this link:
    https://www.videohelp.com/forum/viewtopic.php?p=725433#725433
    ...for the steps I take to go from DV cam to DVD disk with menus and good quality. I don't claim it's the best way or the right way as there's loads of ways and loads of different tools. But it will give you a good insight into what you need to do, typical tools and settings.
    If your aiming to get over (approx.) 100mins onto a DVD, you'll either need to reduce the quality (by reducing the bitrate, see below) or keep the quality and split the output on more than 1 disc.
    A bitrate calculator is used to tell you what bitrate you need to use either:
    1. As a max for Constant Bitrate encoding - CBR, or
    2. As the average for Variable Bitrate encoding - VBR (as I use in the link above).
    A good one is the DVDRHelp Bitrate Calculator, but there are others in the Tools section.
    Hope that helps. Good luck - It's a minefield and seems hellish at first, but the effort is worth the reward and the satisfaction.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  6. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    My method....
    1) Pinnacle Studio 8.10 to 'capture' to HDD
    2) Studio to edit, add transitions etc. and save as an avi (same settings as capture)
    3) Encode with TMPGEnc 720 x 576 (PAL) 8000CBR
    4) Author with Ulead Movie Factory 2.0
    5) Burn with RecordNowMax
    Of course you can encode with Studio, you can author with Studio and burn with Studio.
    I'ts just my preferences.
    I can't fault Studio for working with DV.
    Analogue is a different matter.
    Will
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
