How do i um go abouts this? i have 2 mpg files and i want to put them on a dvd, i also want a small menu where i can select which episode to go to of something.
Thanks.
1) Make sure that your mpg files are DVD-Compliant. For specs, see top l/h column this page ->DVDR. Also, combined file size should not exceed 4.38 gig.
2) You will need to author/burn. One application that can do such is TMPGenc DVD Author... a trial copy is available.
3) Suggest using rewritable disk to begin with to avoid coasters..
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
VC-1 to Mpg-2 and MP4-AVC to Mpg-2
By Bruce Kuhn in forum DVD RippingReplies: 6Last Post: 10th Jan 2008, 18:06 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
