  1. I have two films that are XVid DVD rips. Gspot does show some differences. One movie worked fine using TMPGEnc DVD Authoring to make a DVD-R but the other came out jerky as hell. Almost like it's doing each frame twice with a slight pause between each. Both played perfectly in Windows XP. So I tried using TMPGEnc to convert it first, same result. Tried using Virtualdub to redo it first but still no luck. Help please anyone. This post has been modified by me to be more politically correct. My apologies for the earlier version.
  2. Banned
    Dec 2002
    as Kill Bill is not released yet, no one will reply to your post because it violates forum rules.
    read the rules and then maybe someone will help you
    Sep 2003
    University of Ottawa
    I've learned that after at least 3 beers, I don't notice any jerkiness....
  4. Member richdvd's Avatar
    Oct 2003
    Toronto, Canada
    When is it coming out?
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    According to AMAZON.COM the release date is KILL BILL VOLUME ONE is APRIL 13, 2004
    Here is a screen shot of the DVD cover
    I can't wait myself to see it again
    - John "FulciLives" Coleman
