I have gotten 2 Redundacy errors since I have started Shrinking DVDs wwith DVDShrink 3.1.4. I never had this with Ver. 3.1.2. Has anyone seen this problem also with 3.1.4?
did you get this error as you were ripping with Shrink? if so Shrink's forte is not ripping but encoding. use DVD Decrypter for ripping instead...much better (allows you to skip bad sectors, etc.)
Hi you two.
ukcat, this error is generally indicative of a dirty or damaged disc.
Try cleaning it and see if it then works.
Cyclic redundancy check error
By Arch3type in forum ComputerReplies: 6Last Post: 16th Jan 2011, 01:32 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
DVDshrink error
By rubberman in forum ComputerReplies: 1Last Post: 3rd Sep 2008, 22:51 -
I/O Error (Cyclic Redundancy Check) - where does my problem lie?
By xxjustinukxx in forum Authoring (DVD)Replies: 3Last Post: 11th Apr 2008, 21:35 -
Cyclical redundancy, what is it?
By moviebuff2 in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2007, 09:47
