hey, I just realized you can edit MPEG-1 video files easy as you like using a small program called Goldberg (http://www.macupdate.com/info.php/id/5234) Here's my question: will it work with MPEG-2 files if the Quicktime MPEG-2 codec is installed? Maybe someone could try it out.
Anyhow, even if it only works with MPEG-1s it will be a real time saver.
MPEG2 files do open and play, but how you're getting it to edit anything is beyond me.
Hrm well I'm kinda gobsmacked. This actually works (sort of).
AntnyMD you can select a chunck of the mpeg2 movie by using shift drag or shift click in the slider. You can then copy and paste into a new document (this is working on cinematize output i was previous converting in order to cut out stuff). When you save the new file the size doesn't drop very much though, for example I was copying about 10% of the footage in a 300MB mpeg2 mov, re-saving that 10% as a new file results in a 180MB file. -
Thanks for these responses. Actually, I had meant to post a follow-up saying that with MPEG-1 editing, Goldberg seemed to just create something like a "reference" movie that was exactly the same size as the orginal. But if with MPEG-2 the files come out smaller (even by a disproportionate amount) then perhaps something more complex is going on.
Originally Posted by thoughton
Yeah it's kinda obscure since they dont give you the bookend thingies (nice technical term there) that quicktime player has. The only reason I tried this was cos it was also how you selected parts of a movie back in Movieplayer 2.5.1. How's that for some useless trivia :P
I finally got a minute to try this ... and it works just as you said. I was mostly impressed that it kept the audio and video in sync! However I selected about 10 minutes of video to clip out, and it should have made a file that was roughly 200mb .. but the file it made was 686mb! Anyone else experience that?
Yeah I defintely notice the file size thing. Sometimes a 30% clip will be the same size as the original and somtimes a 10% clip will be about half the size of the original. Weird. I am guessing it doesn't actually 'cut' the mpeg in the places we specify, but keeps a lot of the unwanted data in order to build up the image in the part you do want. But then again I'm probably talking out of my arse :P because it seems like if it did work this way then cutting from the beginning of a clip should preserve all the required info to build up the later image. We need someone who's brainier about mpegs to explain!
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 11:11 -
MPEG editing
By mkr10001 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 23:54 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Editing Audio on only part of an mpeg file !
By acestu in forum EditingReplies: 15Last Post: 23rd Aug 2008, 10:15
