  1. does the deep analysis on dvdshrink really make the picture that much better? i want to copy one of my dvds with everyhting on it, the movie compression is at 53.3% or something like that, will a deep analysis really make it that much better? ive set the menus and extras to the lowest possible percentage and took out all subtitles and non dd 5.1 sounds
  2. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    just do it, unless you are seriously strapped for time. but since you are making a backup of a movie you already own, then time shouldn't be a factor.
  3. the movie compression is at 53.3%
    even with DA you are asking Shrink to do a lot. best solution is to burn to a dvd-rw and view the results before committing to dvdr.
