I have an MP4 video file that opens with Quicktime. I can either export it to AVI -or- open in TmpgEnc and convert to SVCD. For one, I don't care for the TmpgEnc result because CCE is better in my opinion. And, I don't want to save it as a AVI in QT and because it only lets you use cinepak, DV, Indeo encoders. Bottom line, does anyone know of any good site with information about converting FROM this format -or- any tools out there that can deal with it? I would really love to figure out a way to import it into CCE. Thanks for your trouble.
load it into tmpgenc and go file -> save as -> uncompressed avi
load avi into cce - though you could get about the same quality from tmpgenc anyway...
you could also frame serve (or convert it) it from tmpgenc or avsyth or virtualdub"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hey thanks for the reply. I had forgotten about exporting to AVI from TMPGENC. It does take as long to do that as it does to just convert in Tmpgenc. I would like to frameserve but am not sure how to do this with VDUB or TmpgEnc for using with CCE. I cannot open MP4 files in VDUB. Thanks.
Tool that gives more info about .mp4 than GSpot
By Wam7 in forum Newbie / General discussionsReplies: 15Last Post: 7th Nov 2019, 05:51 -
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 20:46 -
media info not showing the video properties of mp4 files when pointing
By sumeshkri in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2010, 20:02 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
mkv/mp4 720/1080p birate info
By ckamc in forum Newbie / General discussionsReplies: 7Last Post: 29th Feb 2008, 07:55
