Has anyone bought this device on Ebay? Basically a small box with cords in and out that purports to be able to transfer VHS to your PC in high resolution and sells for $50 or $60?? Does it work?
A sample is:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2980969960&category=21166<br /> <...ynnsABCs<br />
here is the company that makes them and additional info http://www.kworld.com.tw/ (north america - http://www.kworldcomputer.com )
on paper it has good specifications ... it requires USB 2.0 for dvd resolution.... so beware if you have only 1.1
the company makes some neat gismo's
these are only $25-50 RETAIL .. so ebay buyer beware ... if you pay 60$ you are being ripped off ...
http://www.dealsonic.com/kwxpdvdmausb.html
http://www.cameras-plus.com/p56-21166-mpeg4-usb-xpert-dvd-maker-video-editing-new.html
http://www.audioexchange.com/dvdmakerusb20.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks BJ_M
I saved $10 in shipping charges by buying direct from one of your sources. $4.95 instead of $14.95 in Ebay "handling charges".
Can't wait to try it when it gets here.
LynnsABCs -
I had tried the V-Stream Xpert TV-USB 2.0 which was supposed to be a better one than the wire (style) USB capture. It's now back to the store.
Read my review on V-Stream USB here:
https://www.videohelp.com/forum/viewtopic.php?t=202070
External HD for video editing (USB 2,3 or eSATA) ?
By sdsumike619 in forum ComputerReplies: 2Last Post: 4th Apr 2012, 16:13 -
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 02:02 -
Is it possible to capture video through a USB 2.0?
By brugesnyc in forum Capturing and VCRReplies: 5Last Post: 10th Mar 2009, 12:15 -
video capture thru usb
By jguffey in forum Capturing and VCRReplies: 1Last Post: 31st Oct 2008, 10:49 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18
