I have just bought a new dvd writer and I just cant seem to burn any of my avi files on to a 4.7GB disk in dvd format and fit. for example I open the avi file in mainconcept mpeg encoder and convert it in to a mpeg 2 file = 1.80GB then drag it in to a program called Ulead DVD MovieFactory 2 then it start to convert it in to dvd format then it stops and says that the out put file is going to be too big and I have to insert a bigger disk. I have tried this on a few trial programs not just Ulead DMF2 and they all do the same sort of thing.
I no some one out there can stop my torment and help me it would be a massive help cheers.
[/b]
I know nothing about MovieFactory, but it sounds like it's forcing a re-encode when it's not needed. Is there an option to stop that? If not, try authoring and burning with some of the free tools available here. If your file is 100% dvd compliant, you should be able to do it pretty easily.Originally Posted by notaclueFight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
1GB AVI to DVD doesn't fit on DVDR?
By juggaloninjachoo in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 14:32 -
I have a 4hr mpeg 2 video and i need to fit it into a 4gb dvd-r
By missyfy in forum Authoring (DVD)Replies: 4Last Post: 3rd Feb 2011, 05:12 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:18 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 22:08 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43
