Ok, am I wrong, or can you not join 2 seperate disc movies with this newer version? I'm working with the Godfather Part 2, and it's 2 discs. This is accomplished very easily with Shrink 3.0b5, just by re-authoring both discs, then dragging the second disc part onto the first disc part. 3.1.2 doesn't let you do this. Oh, I'm talking about using the ripped movie files, not actually doing this with the discs.
You should be able to do that with 3.1.2 also. Just go into reauthor mode and then on the right hand pane, drag over the first title and then navigate to the folder that has the other rip and drag that one over as well.
Version 3.1.2 is the best yet I think. In reauthor mode just navigate to your movie location and double click the title you want to add first, then nav to the next location and do the same.
I always use Dvd Author and at least create a simple main menu then use Shrink to make that 2 movie project fit a disk.
Good luck. -
yes... you probably want to rip both to the hard drive. i would anyway. one other thing i forgot to say before... when you go into re-author mode, the right hand pane is an explorer type window, you can just navigate to the folders on the hard drive. when you go to a "VIDEO_TS" folder, you will see the menus, titles, etc of the ripped movie.
question about dvd shrink
By marlo in forum Authoring (DVD)Replies: 5Last Post: 29th Aug 2010, 04:22 -
Hello I'm New & I Have A Question About DVD Shrink 3.2
By taffy1967 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2010, 04:28 -
question about DVD Shrink
By Bamahusker in forum DVD RippingReplies: 7Last Post: 1st Mar 2010, 20:48 -
DVD Shrink and Nero Recode question.
By siratfus in forum DVD RippingReplies: 8Last Post: 13th Jan 2010, 21:49 -
question regarding analyze in DVD Shrink
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 8th Jul 2007, 08:31
