There is this one setting - well more than one - in TMPGenc that I keep wondering about.
'No motion search for still picture part by half pixel'
Up until now, I have used the wizard default - which has this checked. But now I wonder. When I cap TV action episodes like Star Trek, and play them back after conversion, I do notice a slight blurring on movement - like it's trying to focus, but the frame is too fast. It does not last long, and I'm not sure if it's in the original source that way - but I doubt it. Still or very slow scenes are in focus.
Does this setting have any impact on what I'm describing? And do you leave it checked?
Actually, it does have an effect and it's the reason you are seeing this "blurring" occur in particular scenes. Basically, you are sacrificing some quality loss in one type of scene (motion) to improve quality in another type of scene (still/little movement). I always uncheck it.
@ All,
These two links:
http://dvd-hq.info/Compression.html and
http://www.lordsmurf.com/convert/tmpgenc/tmpgencplus.htm
...both provide good details on the settings in TMPGEnc. The first is specifically for DVD compliant MPEG2, with the second being for MPEG1 & 2.
I hope they help, or are at least of interest.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I had read both those sites before, and while I tried what they had detailed, I also have experimented with small clips. I didn't see any difference ( I have old eyes. ), so I got to wondering what other's opinions were.
So how do you keep both dynamics?
Would I have to switch to 'high quality (very slow)', or is there another encoder to consider.
Perhaps one that is faster also. (Not asking for much am I?)
With bitrates > 2500kb/s, it doesn't really count.
With lower bitrates, mostly VBR, sometimes help, sometimes no. Mostly no.
I don't suggest it.
Diamond Search for motion estimation
By bijo911 in forum ProgrammingReplies: 2Last Post: 10th May 2011, 18:26 -
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 10:40 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
